Time To Apply Thinset Changed? Mix Different Now? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-23-2012, 02:45 PM   #1
time to apply thinset changed? mix different now?
Its been a few years since I did a tile job (05') but after setting up my tile job (bathtube, hardyboard, redguard waterprf) I'm running into a real issue with my thinset drying out well before I'm finished with my mix amount. I seem to remember having 30-45 mins to get it on the surface but that doesnt seem to be the case now?
chrisinNJ is offline   Reply With Quote
Old 05-23-2012, 06:27 PM   #2
DIY staff
Rewards Points: 7,174
Exactly what brand and name---You may have grabbed a bag of rapid set by mistake---
45 minutes to a bucket (more or less ) is typical---hot water will shorten the set time,too.
Old 05-23-2012, 07:03 PM   #3
standard bag of versabond flex fortified thin-set. I thought maybe the bag was old so bought another from a lumber yard (with a quicker lot turn over) but had the same result. I thought maybe I had bought speedset as well, and even switched to a bottle water mix (cold) which helped a little. I just remember the window from mix to wall being much more forgiving then this and thought I would ask.
V E R SA B O N D F L E X
F O R T I F I E D
T H I N - S E T M O R TA R
Old 05-23-2012, 07:16 PM   #4
DIY staff
Odd--I've used that--usually plenty of open time---is it hotter than usual in your neck of the woods?
Old 05-23-2012, 08:25 PM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
Fortified thinset has polymers in the mix unlike regular modified thinset and unmodified takes for ever to dry therefore not recommended to use under objects unless outside.
Anyways I once had to level out a bathroom floor almost 1/4" dip in one side the only thing I had to do it with was modified thinset and poly milk mix
Long story short I was trying to beat the clock the stuff was drying up on me so fast cuz I added the mix that I never thought I was going to make it work.
JetSwet is offline   Reply With Quote
My first time playing (literally) with mains power Red Squirrel Electrical 16 05-16-2012 02:58 PM
Diy'er runs out of time & tools turning to the Pros Learn2Build Painting 5 09-20-2010 12:24 AM
Is thinset always necessary? 123 Tiling, ceramics, marble 2 04-29-2010 07:01 PM
Thinset application question poolecw Flooring 2 10-15-2008 03:51 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 06:39 PM
