Tiling Steps - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-24-2011, 11:27 AM   #1
tiling steps
I have a treated wood front pourch we have tiled it. The tile pulls away from the risiers on the steps and cracks on the flat edges on some steps. What can I do to keep the tile from pulling away from the risiers and cracking on the steps as well. We have tried wire mesh ? Also is it because of wood has movement and the change in hot & very cold weather throughout the year ? Please help me out im also having grip issues in the winter thanks!!!
lushie is offline   Reply With Quote
Old 04-24-2011, 07:17 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well first of all...
1. You never apply tile directly to lumber, it never lasts.
2. Nextly you never use "treated" wood anywhere in any type of a tile installation, it never lasts.
3. Stairs (steps) are always problematic unless they are made of concrete. They move when traversed. A two hundred pound man can exert more than four hundred pounds of force with each step when descending stairs I've been told.
4. Everything you have described is exactly why you should never do what you have done.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
DrHicks (04-24-2011)
Old 04-24-2011, 07:59 PM   #3
Learning by Doing
Leah Frances's Avatar
Lushie - I realize that Bud's post isn't very helpful to you. But there really isn't a lot to suggest to help, for the reasons he stated. Sorry.
To everyone else: this is a good example of why telling the pros that you don't want to or plan not to take their advice leads to failure. Yes, there are many ways to do things, but some things just don't work... like tiling directly on a wooden porch.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following User Says Thank You to Leah Frances For This Useful Post:
oh'mike (04-24-2011)
Old 04-25-2011, 03:51 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Quite to the contrary.
My information is helpful in that it should be warning enough not to spend any more time or money trying to repair something that isn't going to allow itself to be repaired. Rather, the thing to do would be to take it all apart and re-do it using lasting methods next time.
XXX
Exterior Wood Steps with Fieldstone Risers Leck Building & Construction 1 06-29-2010 08:32 PM
How long between tiling steps? ptraz Flooring 4 03-12-2010 07:13 PM
Rebuild concrete steps leading to basement gruntman Building & Construction 32 09-30-2009 11:55 AM
Re-staining inside steps saggdevil Painting 10 09-20-2009 06:40 PM
wood front porch steps dlhein Carpentry 4 05-11-2008 08:06 PM
