Tiling Step Risers - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-09-2009, 10:18 AM   #1
Tiling Step Risers
The wood on my step risers is a little beat up, so instead of painting, I was thinking of putting 1/4 veneer to match the refinished threads or maybe tiling the risers using a ceramic tile. I've seen tile on risers before and think it looks good.
If I tiled the risers, can I use standard tile glue? What about grouting, what would I use? In general is this a good idea, or can I expect trouble down the road because of movement/vibrations on steps?
ironmanDIY is offline   Reply With Quote
Old 03-09-2009, 11:01 AM   #2
Remodeling Contractor
Both are not good ideas. No way to make the treads look good with a 1/4" veneer. How would you treat the bullnose edge? And tile to the rises would soon fail. (maybe a week or two)
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 09:37 AM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 04:44 PM
How Should I Frame this Single 10' Wide Step? Chris' Place Remodeling 4 04-02-2008 10:31 PM
Ceramic tile on a little step... kbens74 Flooring 8 01-04-2007 11:45 AM
