Tiling Step - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-07-2013, 01:44 PM   #1
Rewards Points: 528
Tiling step
When tiling a single step (12 by 12 ceramic)what techniques are used on the front edges where they meet , where many step onto and what type adhesive and grout,size notch?
Its at entrance into bathroom from other room.
Any info is appreciated
hidden1 is offline   Reply With Quote
Old 12-07-2013, 10:12 PM   #2
Rewards Points: 918
I have used a through-porcelain and just put the tread on top of the riser, with an 1/8 joint there.
If you don't like this, you can go with the Treppe (step) profile from Schlueter. Maybe there are other manufacturers of profiles out there who offer a stair edge profile as well.
As far as what is underneath, I have just used 2x8 risers and 2x10 treads spanning 3' with a wall on either side. On top of the lumber I mortared on denshield and tiled on this.
I've had no problems and the installation is very solid.
You can use a 3/8" trowel.
As far as grouting, there isn't much used. It is all caulk in the changes of plane, so you only have grout in the horizontal and vertical joints on the treads and risers and skirt.
cleveman is offline   Reply With Quote
Old 12-08-2013, 12:39 PM   #3
Rewards Points: 528
I also meant to ask if i use fortified or un fortified adhesive and would i need sanded grout instead of unsanded if there is a wider size space between the tiles?
I will be matching up to floor ,above single step, horizontally, and need to keep it about same as far as tile spacing .
I dont have side support as in a wall on left/right ,just the one its facing,and will be tiling sides also.
Thanks for the info..
Old 12-08-2013, 01:30 PM   #4
Rewards Points: 918
Use a modified latex mortar, sanded grout, and a matched sanded caulk.
Can starting step tread be 3/4" deeper than other treads? hkeiner Carpentry 8 02-18-2013 11:24 PM
Hang drywall vertical or horizontal nickm1024cobra Drywall & Plaster 54 03-30-2011 12:37 PM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 08:19 PM
tiling outdoor step kristinmcdonald Tiling, ceramics, marble 6 06-09-2009 12:02 AM
Tiling Step Risers ironmanDIY Tiling, ceramics, marble 1 03-09-2009 11:01 AM
