Tiling Shower Walls - Tiling, ceramics, marble - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-17-2013, 10:19 PM   #31
Tileguy
JazMan's Avatar
Rewards Points: 346
I have never used backer rod in tilework unless it's a wide expansion joint. Backer rod is indicated for joints that are 3/8" wide and at least that deep, not 1/8" inside corners.
I believe it's best to caulk the day before grouting if time allows. Otherwise grout, then remove it with a utility knife and caulk.
Jaz
Old 06-17-2013, 10:24 PM   #32
Rewards Points: 4,796
My understanding was that the backer rod was used as a technique to remove grout, not to leave behind caulk. Jay2013's response to that post made no sense, but it seems to me that ripping out backer rod behind the wet grout ought to work. Just seems like too much effort when other methods work and take less time.
jeffnc is offline   Reply With Quote
Old 06-18-2013, 05:43 AM   #33
DIY staff
Rewards Points: 7,174
Jaz
I learn something new every day-----Use the method that works for you---
Old 06-18-2013, 08:57 AM   #34
Pro
Rewards Points: 91
Just piping in to say absolutely, replace that shower valve, and don't skimp on on it. A good pressure-balanced valve, easily maintained, with integral stops, will run you about $100. Buy the shower trims separately.
CarpenterSFO is offline   Reply With Quote
Old 06-19-2013, 09:28 AM   #35
Roofmaster
Rewards Points: 2,172
Very Nice Work! You should be proud!
Replacement tiling in bathroom on damaged walls JeanB Tiling, ceramics, marble 0 04-20-2012 09:52 PM
Installing 2 shower heads on separate walls? mallory_ratliff Plumbing 2 07-12-2011 04:56 PM
Ideas for shower stall walls moneymgmt Building & Construction 15 09-01-2010 01:48 PM
building shower walls with concrete canyongirl Building & Construction 13 03-14-2010 12:44 PM
Tiling over plastic shower base newproject Building & Construction 5 02-21-2009 07:40 PM
