Tiling Over XPS - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-20-2013, 02:02 PM   #1
Rewards Points: 143
Tiling over XPS
Hi everyone,
I am looking for ideas on how-to tile over 2" inches of XPS layed over a concrete basement floor. Ditra is very expensive and we currently have a few materials in stock that we would like to use.
We have 1/4 & 3/8 cement board and also 7/16 OSB and 3/4 plywood.
The foam will have routed pex tubing running in between. Then we planned on putting OSB screwed into concrete and then cement board with thinset and then tile on top. OR 3/4 plywood screwed into concrete and tile on top of that.
I was wondering what everyone's take on the install was. I haven't been able to figure out what the deflection of XPS would be. Its rated for 25psi compression.
cloves is offline   Reply With Quote
Old 03-21-2013, 08:44 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 290
Please direct us to the specification from a tile association or the manufacturer of XPS that says this type of installation is recommended. Need to read all the data including the fine print regarding its use below grade where there's moisture present.
Jaz
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 09:37 AM
unstable subfloor for tiling hohadcr Flooring 2 08-27-2010 01:10 AM
Wall Tiling ranapratab Building & Construction 4 10-21-2009 08:30 AM
First tiling project, need some help DIYD Tiling, ceramics, marble 1 08-06-2009 07:15 AM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 04:44 PM
