Tiling Over Vinyl Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-24-2013, 10:24 PM   #1
Tiling over vinyl floor
I am planning to install ceramic tiles on my kitchen floor. Current floor is vinyl. My contractor suggested that I don't need to remove the existing vinyl sheet, rather he would nail thin ply wood sheets on top of the existing vinyl floor and then install ceramic tiles.
My questions:
1. Is there any problem, if I leave the old vinyl sheets underneath the tile floor
2. What precaution I should take if I decide to leave the vinyl sheets under
Thanks in advance for your answer.
jrahman is offline   Reply With Quote
Old 08-25-2013, 12:27 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 290
It's obvious you're talking to the wrong contractor, or is he a handyman? He has no clue.
Find a tile contractor and then let us know what he proposes, there's several ways to go.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
joecaption (08-25-2013)
Old 08-25-2013, 08:46 AM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
And the several ways to do this doesn't include leaving the vinyl.
JetSwet is offline   Reply With Quote
Old 08-25-2013, 09:12 AM   #4
Bill Kearney
Rewards Points: 1,174
You should not leave the vinyl. For several reasons, the most important of which is you won't have a solid base for your new tile. Tile needs a rigid base, otherwise the floor will flex and that will lead to cracks in the grout joints and even the tile themselves.
Another reason is this will raise your floor level. Making it a problem for your entrances into other rooms. And also a problem for your appliances because the floor will then have a 'lip' in front of them. This sometimes makes it very difficult to get them out for service or replacement. You can't run the flooring under them because then they'd be higher than the existing cabinetry.
Pull up all the old flooring. In doing so you'll also be able to confirm that the subfloor is in good condition.
On a side note, have you confirmed that your floor joist structure is capable of supporting the weight of tile? It's called deflection and unless your joists are correct that too can cause tile to crack (even without the old floor still being there).
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
Old 08-25-2013, 09:36 AM   #5
Rewards Points: 13,270
Any thin plywood is never a suitable underlayment for any tile.
Is the vinyl installed over 1/4 now? If so it needs to go also.
Going to need to know what size, spans and spacing your floor joist are and what's there now for subflooring and underlayment to make any real suggestions on how to proceed.
I for sure would let that "contractor" have anything to do with the floor if that's his idea of a suggestion!
Tags
tile , vinyl
hardibacker and tile over vinyl floor Jonscheets Flooring 5 05-01-2013 08:16 AM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Preparing kitchen floor for Vinyl tile NewLook Flooring 6 06-08-2011 10:00 PM
Remove old vinyl floor that's curling at the edges? julzology Flooring 9 03-20-2011 07:07 PM
New porcelain tile to replace vinyl floor in kitchen PatrickGSR94 Flooring 5 03-03-2011 02:42 PM
