Old 04-13-2014, 12:11 PM   #1
Share |
Tiling over Structolite- Primer Required?
Hello,
I have just finished plastering my (dry area) bathroom walls using Structolite. Should I apply a coat of primer/ sealer to the Structolite before I tile? If so what product would you recommend?
More Information:
-The Structolite has a light texture to it (similar to exterior stucco).
-I will be using 3" x 6" subway tiles (3/8" thick) adhered using VersaBond Fortified Thin-Set Mortar.
Many Thanks,
Ben
Bhfs100 is offline   Reply With Quote
Old 04-13-2014, 06:31 PM   #2
Tileguy
JazMan's Avatar
Hi Ben,
Your substrate is a gypsum coating and so I would treat it as Custom Building Products recommends you prepare gypsum and light weight concrete. While you're the HD, pick up some Redgard.
Prime the Structolite with a diluted primer consisting of 1:4 Redgard/water. If the surface is very porous, apply a second coat. At this point you can spread the Versabond or any other modified thin set and set the tiles. Or you can apply neat coats of Redgard for the purpose of waterproofing or crack isolation, prior to setting the tiles.
Jaz
Tile 4 You LLC Troy, MI
DITRA Installs - KERDI Watertight-Mold-Free Showers. I have NEVER made a mistake, I thought I did ONCE, but, I was WRONG! A+ BBB rating - est. 1987 - over 50 yrs. exp.
Old 04-15-2014, 03:38 PM   #3
Many thanks JazMan,
I did just as you said by applying one coat 1:4 diluted Redgard followed by one coat of neat Redgard. So far the thin-set is going on well and not drying out too quickly.
Thanks again,
Ben
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 08:00 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Fresh acrylic primer + paint not sticking paul_l Painting 12 09-23-2010 09:06 AM
Thoughts on using Exterior SW Duration as a primer. refreshrate Painting 7 06-09-2009 09:40 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
