Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 04-23-2010, 10:08 PM   #1
Tiling over shiplap subfloor
Hi,
Renovating the bathroom and have 3/4" shiplap for subfloor.
Tried to glue and screw 1/4" plywood to "beef it up" a bit and it just bounced in between the joists(16" o.c.) so I pulled it up before the glue could dry as I didnt want to continue on with porcelain tile and have them cracking.
Should I skip trying to add another layer of subfloor and go with Schluter Ditra where the tiles will be laid and leave the shiplap under the bathtub?
Thanks for any responses...
Catahoula is offline   Reply With Quote
Old 04-24-2010, 07:05 AM   #2
Ceramic tile requires a subfloor at least 1 1/4" thick and VERY stiff. Plywood is needed over T&G subfloor, but more than 1/4". Hardibacker or duroc, glued and screwed down, qualifies.
Old 04-24-2010, 01:30 PM   #3
I'm not sure what code is in your part of the world, but here it's 5/8th over 5/8th (or 1.25 inches) like Just Bill said. I'd suggest screwing down 5/8" plywood over shiplap as there is significantly more movement there than there would be in a plywood subfloor.
Don't just add another 1/4" sheet of plywood, two sheets of 1/4" inch aren't as stable as one sheet of 1/2".
Good luck and have fun, it should look great when you're done!
rcuerrier is offline   Reply With Quote
Tiling, Subfloor, backerboard????? mablack1970 Flooring 5 02-17-2010 08:55 PM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Tiling Over Wood Subfloor? bz2005 Flooring 3 04-02-2009 11:14 AM
Tiling - Gap in plywood (sub)floor mcg Remodeling 5 01-15-2009 05:21 PM
preparing for subfloor before tiling zazu2056 Flooring 1 10-29-2005 09:09 AM
