Tiling Over Old Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-01-2011, 01:18 PM   #1
Just call me Andrew
Rewards Points: 1,020
Tiling over old floor
I want to tile a room in my parents' house. The current flooring is about 35 years old, some sort of old glued-on tile (best i can tell). It's very thin. I am not sure if there is any backerboard underneath it or if they are adhered right to the wood subfloor.
What is the best/easiest way to do it? Can I get 1/4" hardiboard , screw it down (mortar too?) to the old tile and just put porcelain/ceramic right on top of it? Raising the floor 1/2" to 3/4" should be ok.
Also, how do I cut curves in tile? I have a rotozip, is that a decent tool for the job?
This will be the first time I've ever tiled anything, so I appreciate the advice.
Andrew
secutanudu is offline   Reply With Quote
Old 03-01-2011, 06:22 PM   #2
DIY staff
Rewards Points: 7,174
Knock the old tile off the floor--You will find that it will bounce right off--scrape the floor as clean as can be---set your Durrock in thinset (1/4" is all you need) --screw it down--ready to go.
Let us know what the floor structure is--Plywood/OSB--floor joist size and span.
Roto Zips make terrible tile cutting tools----what sort of curve are you hoping to cut?
Old 03-01-2011, 10:25 PM   #3
Just call me Andrew
THe joists are 2x8s, I believe 16"oc. Plywood floor, I think (I need to go there to check for sure).
If that tile doesn't come off easily, can I put backerboard right on top of it? I need to curve around the bottom of the stairs, the bottom step widens and has a curve around the edge.
Andrew
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Tiling a bathroom floor and installing under floor heating tlovesb Flooring 6 02-04-2011 06:01 AM
Tiling on cement floor hollya Flooring 1 02-02-2010 02:07 PM
tiling kitchen...how to treat electrical outlet on floor? tarheelblue Flooring 3 01-28-2008 03:31 PM
