Tiling Over New Concrete - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-12-2008, 01:21 PM   #1
47_47's Avatar
Rewards Points: 74
Tiling over new concrete
We had a new concrete slab poured in January of 2008 (15'x 30'). Slab is 4" thick over a moisture barrier, no in slab radiant heat, no control joints and at grade level. There is also a man door to the outside. Plan to install ceramic tile in Feb.
The slab is flat and does not have any cracks. Can I just use modified thinset between the ceramic (12x 12 or 13x 13) tiles and the slab or do I need a membrane?
Thank you
47_47 is online now   Reply With Quote
Old 12-12-2008, 01:42 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Modified thinset should be fine as long as the temerature doesn't drop below 55 degrees during the process and for several days afterward.
Old 12-12-2008, 01:49 PM   #3
47_47's Avatar
Rewards Points: 74
Bud,
Thanks for the answer, one more question, is the 55 air temp or slab temp?
Mike
Tiling Over Painted Concrete Floor?? kiss44 Flooring 13 07-06-2011 04:41 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
Tiling a porch over a painted concrete surface Harls Building & Construction 1 07-14-2008 07:34 AM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
