Tiling Over Fiberglass - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-01-2012, 05:19 PM   #1
Tiling over fiberglass
Brand new and want to thank in advance for any help given!
Recently redid our bathroom. New tub, new tile, the works! It's gorgeous! Well almost.
When installing the fiberglass jacuzzi tub, we rested the hardibacker on top of the flange. When tiling, we went with decorative 2 inch glass tile placed directly on top of the fiberglass flange. 18inch tile went above. Waited the adhesive manufactures recommended drying time. Grouted and It looked great!
A few days pass and the grout between the glass tile is crumbling. Everywhere else holds up fine.
Today I pulled out the small tile with intentions of redoing and discover the adhesive on the fiberglass was still pasty (not dried) and didnt adhere well.
So my question is, can I use mortar on the fiberglass to reattach the glass tiles? Or what would you recommend? Thank you!
Diyerwacause is offline   Reply With Quote
Old 02-01-2012, 05:35 PM   #2
Rewards Points: 13,450
I never would have installed a small detail tile at the bottom, to many grout lines that can leak.
The tile should have been about 1/4 from the tubs edge and caulking used not grout.
Old 02-01-2012, 05:46 PM   #3
Thank you for your reply.
Unfortunately the entire bathroom has already been tiled which makes removing and correcting placement a no go. Do you see another option for correction and allowing for a pleasing appearance?
Funny, you should mention the grout as I did specifically ask at our home improvement if we should use a sanded or synthetic grout in the tub area. Sanded was recommended :s
Old 02-01-2012, 05:54 PM   #4
DIY staff
Rewards Points: 7,174
You should have set the entire tile job with a powdered modified thinset---what did you use?
I didn't see the glass tiles in your picture--only what appears to be a wide band of white caulk
Could you take a picture from farther back that shows the detail tile better?
Old 02-01-2012, 05:55 PM   #5
Grout is never used where tile changes direction or comes in contact with a differet material.
Sanded grout would only be used in the field of tiles with spacing of 1/4" or more. Never at the tub to tile area.
If you used sanded grout for the rest of the tiles you could have bought sanded caulking in a matching color.
Old 02-01-2012, 06:01 PM   #6
Rewards Points: 582
now or later you will have to fix it right sorry ...ben
Old 02-01-2012, 06:10 PM   #7
We used Mapei Type 1 tile adhesive.
I had already removed all the small tiles but placed a section back in for sample purposes in this photo.
Old 02-01-2012, 06:24 PM   #8
Thank you for all replies, even the unpleasant to hear (starting over)
Dh says the flange presented problems for him as it was beveled. He says the center was approx 1/2 inch and went to 1/4 towards the sides.
Is this salvageable? What would you do if it was yours? How do we address the beveled flange?
Thank you for all the advice!
Old 02-01-2012, 06:26 PM   #9
DIY staff
Got you!!!
Wrong goop---that is an organic adhesive and should not have been used in a wet area---
As you learned the hard way---it will re-emulsify when it gets wet---
Clean out the gap very well---then use a white modified thinset---"Mud" What Is It? - Kitchen & Bath Remodeling - DIY Chatroom - DIY Home Improvement Forum
Might be you have to add a coat first if the mosaic is thinner than the field tile---then thinset in the mosaic---
You must use a flexible caulk where the tile meets the tub---Grout matching caulks are available--
If you must add a layer of mud before you set the tiles---make a gauged spreader by cutting a cheap plastic putty knife--notch the edge so that it rides on the field tile--and leaves the right amount of thinset on the wall below the field tile.---Mike--
Old 02-01-2012, 06:35 PM   #10
DIY staff
If you had this to do over--(which is not a likely option)--there should have been field tile at the tub--
Often ,if the rolled edge prevents placement flat to the wall, grinding away the back of the tile is needed--
A little bitty tile against the tub is seldom a good choice---to much difficulty getting it flat and straight--
and a lot of movement happens tight there--all in all a weak choice---
Old 02-02-2012, 06:05 AM   #11
Rewards Points: 1,294
Incorrect info removed
I had to fix something like this once before. I had to sand down the gelcoat on the exposed fiberglass to give it some tooth(assuming it is that, it may be acrylic or Styrene). Once that was done I used silicone adhesive to bond the tiles. (do not use siliconized latex). Once done, I had to use a colored caulk for the grout line as the different expansion rates of the tub surround and the tile backer made it imposible to keep grout in the joint between the two. This was on 1/2" mosiac tile.
danpik is offline   Reply With Quote
Old 02-02-2012, 06:21 AM   #12
DIY staff
Originally Posted by danpik View Post
[/color]
This is where the problems started. The tile backer should have come down over the flange. You needed to shim out the wall studs to make it plumb.
[/color]
Actually --stopping the backer above the flange is the recommended method.
The resulting gap is then filled with modified thinset as the tile is installed--
Shimming out the walls in the tub area causes a misalignment problem where the backer meets the drywall---
Old 02-02-2012, 09:02 AM   #13
OK, I guess I am wrong here. I will remove the incorrect info.
The Following User Says Thank You to danpik For This Useful Post:
oh'mike (02-02-2012)
Old 02-02-2012, 09:56 AM   #14
When I shim, I shim all three walls so there is no offset at the drywall.
Never trust anyones advice at the box stores unless you know them.
I've figure out how knows what. Some of the the semi retired people that work there used to be contractors, plumbers, electritions, flooring guys.
You can tell the flooring guys, they all have bad knees and walk with a limp. lol
Old 02-02-2012, 07:10 PM   #15
DIY staff
You calling me a gimp!!!!!
Removing fiberglass batts without fibers all over house darlingm Insulation 7 09-10-2011 09:47 AM
cellulose over blown in fiberglass? deerhunter Building & Construction 1 10-29-2010 10:16 PM
Tiling on top of fiberglass pan janmoulds Flooring 5 03-14-2010 06:38 PM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 03:44 PM
Is fiberglass insulation safe for us with dishwasher? jen78fl General DIY Discussions 10 01-31-2008 05:51 PM
