Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 06-12-2010, 09:22 PM   #1
Tiling over cement patio
When tiling over a cement patio, what type of tile do I need to use. Any special tips would be helpful as well.
Clemey is offline   Reply With Quote
Old 06-12-2010, 09:33 PM   #2
Super Moderator
If freezing can happen look for a tile with an impervious rating.--These are dense enough not to absorb water.---Mike---
Old 06-13-2010, 03:43 PM   #3
Tileguy
Bud Cline's Avatar
Any "quarry tile" or "porcelain tile" is usually suitable for exterior use when freeze/thaw is an issue.
The "ratings" have nothing to do with the body of the tile, they only refer to the wear-surface and suitability of an application as it relates to wear surface.
A tile rated at a 4 or 5 doesn't make it suitable for exterior use. Those ratings are not what determines a tile can be used out of doors.
Old 06-13-2010, 06:07 PM   #4
Super Moderator
Buds right--
installing Slate title to outdoor cement Matky Flooring 53 04-05-2010 08:08 PM
Replace rotted 2x4's in cement patio KennS Building & Construction 3 06-19-2008 12:41 AM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 11:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
