Tiling Over Aggregate - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-21-2011, 11:39 PM   #1
Tiling over aggregate
New to the site here and looking for some advice. I'm looking to refinish a sunroom floor with porcelain tile. Currently the floor in the room is split with half being concrete slab and the other half exposed aggregate. The concrete is somewhat new and the aggregate from what I can tell was put in twenty-five years ago when the house was built. How do I prep the floor for tile? Is the prep different for concrete than the aggregate? Can I lay tile right over it? Any info is appreciated. Thanks.
ryans1 is offline   Reply With Quote
Old 04-21-2011, 11:48 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Describe the "aggregate" portion.
Is this "aggregate" chattahoochee?
XXX
Old 04-22-2011, 12:03 AM   #3
I had to google "chattahooche" and from the images I saw I would say no. The half inch to inch aggregate in my floor are less exposed with 1/8" to 1/4" deep gaps between each stone. Hope this helps. Maybe i'll attach a photo if I can figure that out.
Old 04-22-2011, 12:14 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay, that sounds like typical Portland cement with exposed ag.
If it is solid and not spalling or decaying in some fashion I see no reason you can't go over it. You would have to fill it first I suppose. There is more than one way to do that.
XXX
Old 04-22-2011, 12:16 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
P.S. I forgot to mention you probably wouldn't want to bridge the joint between old and new with a single tile. Need more info on that score.
XXX
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 09:37 AM
unstable subfloor for tiling hohadcr Flooring 2 08-27-2010 01:10 AM
Tiling Over Aggregate Patio patch Flooring 2 03-18-2010 08:13 PM
First tiling project, need some help DIYD Tiling, ceramics, marble 1 08-06-2009 07:15 AM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 04:44 PM
