Tiling Over 2x8 T&G Flooring - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-18-2012, 03:24 PM   #1
Tiling over 2x8 T&G Flooring
The floor of my house consists of 2x8 Doug Fir Tongue and Groove w 4ft span. It is pretty stout. I want to re-tile my bathroom floor, and would like to use the Kerdi waterproofing membrane. Based on the research I have done it sems like I am going to need a lot of layers (too many?).
Here is what I have gathered: screw plywood over existing 2x8 floor, then use thinset to secure CBU, then thinset the DITRA membrane over CBU, then tile. This seems like a lot of layering. Can I eliminate any of these layers? Is my method correct? If I don't use the DITRA membrane, is there something that I should do to the CBU before tiling?
Should I eliminate the CBU and put the DITRA on the plywood?
JOBARR is offline   Reply With Quote
Old 10-18-2012, 03:36 PM   #2
if you use the cbu you do not need the ditra. use one or the other
The Following User Says Thank You to DannyT For This Useful Post:
drtbk4ever (10-18-2012)
Old 10-18-2012, 04:32 PM   #3
Newbie Bill
Rewards Points: 522
You say the 2X8 t&g spans 4 feet. Is that 4 foot span between joists? Or the joist span is 4 feet. If so, what size joists and what spacing?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 10-18-2012, 04:56 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
You can also eliminate some layers by removing the T&G planks,
JetSwet is offline   Reply With Quote
Old 10-18-2012, 07:43 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 388
No he can't Jet. His house is built with the joists 4' apart, he needs 2x lumber as the subfloor. It's typical left coast construction, pier & post.
Jaz
Old 10-18-2012, 08:08 PM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
Jaz
Your right Jaz I didn't read the post correctly yet again....eeeek
Old 10-19-2012, 09:56 AM   #7
Newbie Bill
Rewards Points: 522
Jaz
Wouldn't there still be a great deal of deflection with 2X spanning 4 foot joists?
Bill
Old 10-21-2012, 08:42 PM   #8
Pro
JetSwet's Avatar
Rewards Points: 502
Yes there really should be blocking between joists IMO
Old 10-21-2012, 10:17 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 388
[QUOTE=drtbk4everWouldn't there still be a great deal of deflection with 2X spanning 4 foot joists?[/QUOTE]
You'd think so, but that's how they do it in parts of California, Oregon etc. There is no specification that approves that kind of framing for tile that I have found, apparently it works though.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
drtbk4ever (10-22-2012)
Tags
bathroom floor tiles , ditra , tongue and groove floor
tiling over vinyl flooring? djhaleah Flooring 1 06-18-2011 12:03 PM
Two questions for T&G flooring Mark Harvey Flooring 9 01-06-2011 08:27 AM
Tiling - What makes the proper flooring sandwich? luvdairish Remodeling 13 11-09-2010 10:46 AM
Fir T&G flooring Alvis Flooring 36 05-03-2010 12:21 PM
Refinishing square cut side of 2x6 T&G for flooring cowbore Flooring 1 11-24-2008 01:13 PM
