-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Tiling outdoor concrete patio with copper pennies (http://www.diychatroom.com/f84/tiling-outdoor-concrete-patio-copper-pennies-173231/)
pennytile 02-28-2013 12:45 PM
I love the look of "penny floor" and would like to do it on our 100 sq ft concrete patio. I am planning to create 1 sq ft fibermesh tiles with pennies as it will be much faster to lay them than individual pennies. The question is: what kind of adhesive should I use? different sites recommend glue for indoor installation. Is it possible for outdoor flooring? If I use regular mortar, will it go through fiberglass? What type of grout will be best? How should I seal the floor? I'm new to tiling, even basic advice is welcome. Thank you!
oh'mike 02-28-2013 01:51 PM
You will need to experiment----I think that you should be able to use fiberglass drywall repair mesh---you will need to call a drywall supply house like Ammes to see what sizes are available.
I think ,if you lay the mesh over wax paper, you could brush on epoxy and set the coins into that---
You will want to set the completed sheets to your concrete patio with epoxy thinset---and grout with epoxy grout----
This won't be cheap--but should work well---no sealing will be needed if you use epoxy grout---
The sheets could actually be set into a bed of epoxy grout and completed in one step---experiment---so try a sample first---
Fix'n it 02-28-2013 09:08 PM
when i first read this, i thought you were NUTS
reading that i thought you were even more nuts.
but i googled penny floors. there are some nice looking floors there.
i can't help you. but i do wish you luck.
Maintenance 6 03-05-2013 02:05 PM
Make sure you use real copper pennies (1981 or older) and not the plated zinc pennies (1983 and up). 1982 pennies are a toss up. Concrete will probably eat the zinc ones.
DrHicks 03-09-2013 04:00 PM
Very interesting!
http://big-design.blogspot.com/2011/...ile-floor.html
paintdrying 03-09-2013 04:45 PM
Let us know what you come up with, I would like to do something like that. Very sharp.
Blondesense 03-10-2013 12:41 PM
Cool idea.
How would you seal or protect it?
I would be concerned on how well they would weather outside.
In your shoes I might do one square and leave it outside for several months before I commit to 100 sq feet.
