#1 |
Tiling kitchen. Floor uneven. Going crazy!
Hi, I am new to pretty much everything DIY but am trying to learn so that I can fix up/repair/renovate my house myself. Any help is greatly appreciated.
I am attempting to tile my kitchen floor but am running into some problems. First, the kitchen floor had a hump running down the joist in the middle of the floor. I removed most of the OSB subfloor and found that the joist was causing the hump and was about 3/4"-1" higher than the other joists. So I ground it down and installed 3/4" plywood. Then I noticed the plywood I just put in was still raised up and sloping from the joist I just ground down. The unevenness didn't seem too bad so I went ahead and put down some thinset mortar and began laying the cement board on top and screwed it down. After laying my 4th board, I placed a tile on top of one just to make sure it lay flat. When I pushed on the edges of the tile, the other side would raise up slightly (I would guess around 1/16"). Fearing the unevenness of the cement board and raising of the tile would make tiling the floor impossible, or end up cracking the grout and/or tile, I got frustrated and quit for a couple days. When I resumed working, I took up the cement board then spent 2 1/2 frustrating days scraping up the dried thin set mortar. I also noticed that the original OSB subfloor that I didn't cut out is raised up to 1/8" above the plywood I installed, but then is flush with the plywood in other spots along the same joist. Should I chisel it down? ![]() So...What can I do about evening up the subfloor? I bought some self leveling underlayment (Henry 565 FloorPro) but it was $36/40lb. bag, and the directions say it only covers 43 sq.ft. at 1/8" thickness. My kitchen is about 120 sq.ft. so if I had to level the whole floor with it, it would cost about $120. ![]() Could I just use more of the thinset mortar to even out the low areas, or would the cement board still lay unevenly? ![]() ![]() ![]() ![]() ![]() Specs: Kitchen-120 sq.ft. Thinset Mortar-Mapei (it's polymer enriched!) Subfloor-3/4" plywood and 3/4" OSB Joists-16" on center Tile-12"x12" porcelain Cement Board-1/4" UltraBacker Any help is greatly appreciated! |
#2 |
Super Moderator
It's to early to think------
All flattening efforts from this point will be done from the top of the backer board. Set the board into a bed of morter and nail it down---roofing nails spaced about ever 8 inches---or screw if you prefer-- Them use the self leveling compound----read the bag---I believe henrys requires a primer----I use Jif-set and mix the first layer with a liquid latex I can't help the cost----tile setting can be costly to do properly-----and very expensive when done wrong. only a small amount of correction can be acheved with thinset----to much mud and the tile will drop as the thinset settles and cures---- Leveling clips can be used during the instalation-----they work well--but add a lot to the cost of installation.
New members: Adding your location to your profile helps in many ways.--M-- |
| Tags |
tile, uneven floor ![]() |
| Display Modes | |
| Tiling kitchen | gil35tx | Flooring | 0 | 03-21-2012 02:52 PM |
| Carpet in Kitchen has me going crazy! | Jamie620 | Flooring | 11 | 08-05-2011 07:41 PM |
| smell in basement from non-vented kitchen sink | ahgill | Plumbing | 3 | 10-11-2010 03:39 PM |
| tiling kitchen...how to treat electrical outlet on floor? | tarheelblue | Flooring | 3 | 01-28-2008 04:31 PM |
