Tiling Kitchen Floor With Baseboard Steam Heat - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 06-15-2009, 11:20 PM   #1
Tiling kitchen floor with baseboard steam heat
Hello!
I'm putting tile in a kitchen which originally had linoleum flooring. I plan on using 1/4" cement board as underlayment, and 1/4" tile. Problem is, that 1/2" or more (including thinset) takes me too high up on the baseboard radiators. Does this mean I'll have to remove and raise the radiators to sit on the tile? What all is involved if you've done this before? Thanks!
rustedhorses is offline   Reply With Quote
Old 06-16-2009, 05:07 AM   #2
Remodeling Contractor
you should move the heaters up. The airflow below these units help create the movement of air needed for proper operation.
Old 06-16-2009, 11:01 PM   #3
Thanks, Bob!! I appreciate the reply.
Hotwater baseboard heat sound like loose change ctrait HVAC 1 01-11-2009 09:42 AM
Help with bleeding baseboard heat system robinswendy HVAC 1 12-13-2008 04:04 AM
Baseboard Heat monk4270 Plumbing 2 12-07-2008 06:19 PM
Remove baseboard heat? Patrick B HVAC 6 04-11-2006 04:12 PM
