Tiling Florida Room - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-18-2009, 07:09 PM   #1
Tiling florida room
I have two issues to deal with.
1. I have a section of floor that was cut out and filled with white stone where the hot tub was, about 8x10 area. This stone is about 4 inches deep, can I mix in some concrete mix to solidify the stone and then apply a layer of skim coat over that to level the space??????
2. I removed some indoor outdoor carpet but the glue stayed on the floor, it's rock hard and appears to level out the floor nicely, can I tile over it????
tbishop is offline   Reply With Quote
Old 05-20-2009, 06:13 AM   #2
1. drill into the 4 sides of the cutout and install rebar. This will joint the old to the new. The concrete should be about the same thickness as the existing floor. Fill with concrete, a trowel flush with the old. If still not even after it dries, some leveling compound will bring it up. But use a membrane in this are, as there will likely be some cracking over time.
2. I would chip off the old adhesive.
Old 05-20-2009, 07:28 AM   #3
Tileguy
JazMan's Avatar
Rewards Points: 346
Do as Bill says. Get those stone out of there, prepare the base and have it poured. It'll take exactly 1 yard of cement.
You'll have to cut the adhesive away and get down to bare concrete. Try a tool called a "wallpaper scraper". It has a handle with a 4" razor blade on an angle, should work pretty good. You should be able to go over the concrete after you do the above. If you have the time, it would be a good idea to do several "test-bonds" and allow to set for a week or 2 to be sure.
Jaz
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 07:28 PM
bath room tiling question, laying tile around a curve everyman Kitchen & Bath Remodeling 2 02-14-2009 01:21 PM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
Question about temperature of a florida room randalg General DIY Discussions 1 04-08-2008 11:38 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
