Tiling, Ceramics,marble - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-07-2010, 07:16 PM   #1
Mortar not setting, installed travertine tile over a proflex membrane on sat. and mortar still has not set. Is this normal?
Installed Travertine tile over Proflex membrane on Sat. and mortar still has not set up. Used a premixed premium mortar for stone and tile.12x12 tile 1/4 x 1/4 notched trowel.
jdm63 is offline   Reply With Quote
Old 04-07-2010, 09:11 PM   #2
DIY staff
Rewards Points: 7,174
Oh,boy--I hate to be the one that has to break this to you--You used the wrong setting material.
You should have used modified thinset--the powdered stuff that is mixed with water.
What you used is mastic.--water soluble --needs air to dry--will get soft if it ever gets wet.
with a membrane and a 12x12 tile there is no air to dry it.--
I hope this was not to big of a job---you may have to clean all that stuff off and use thinset.--Mike--
Old 04-07-2010, 09:33 PM   #3
DIY staff
You posted this twice---Sorry --you used a water soluble premix--you should have used modified thinset
That stuff needs air to dry--with a membrane and 12x12 tiles there is no air.
You will need to remove the tiles--scrape off the mastic--scrub every thing clean and use the right product.
I went to their web site--they recommend using modified thinset--that comes in a bag and is mixed with water.
Sorry to be the bearer of bad news---Mike--
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 08:37 AM
Wall Tiling ranapratab Building & Construction 4 10-21-2009 07:30 AM
First tiling project, need some help DIYD Tiling, ceramics, marble 1 08-06-2009 06:15 AM
Tiling bathroom ivaiva Project Showcase 3 08-30-2008 08:24 AM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 03:44 PM
