Tiling A Bathroom Shower Ceiling And Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-13-2008, 12:21 PM   #1
tiling a bathroom shower ceiling and floor
I need to know how to tile the ceiling of shower? and which part I should start with when I get to the tile thanks Marie
marie conn is offline   Reply With Quote
Old 11-13-2008, 12:49 PM   #2
bradnailer's Avatar
Tile the ceiling like you would the wall, using a good tile adhesive. If it doesn't already have backer board, you should install some. You can minimize cuts by starting with full tiles on one corner and working to the least exposed sides. However, you need to make sure you have decent sized cut pieces on the edges. If time isn't an issue, I'd do the floor first, grout it then do the ceiling. Welcome and good luck.
bradnailer is offline   Reply With Quote
Old 11-14-2008, 01:44 PM   #3
Tile and Paint contractor
I'd do the cieling before the floor.
What if you drop a piece.
Plus, grouting a cieling is a very interesting task, and a laborous cleanup.
Matt | tile contractor
Charlotte, NC
MattCoops is offline   Reply With Quote
Leaking bathroom floor patatura Flooring 6 12-06-2008 06:30 PM
Hardibacker on shower ceiling? sharisavage Remodeling 6 10-06-2005 11:40 AM
Cold Air Return near ceiling or floor? jakobus HVAC 3 07-21-2005 10:54 PM
