Tiling Bath Surround - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-07-2011, 09:11 PM   #16
Bud, the tub manufacturer (American Standard) recommended shims for where the tub apron meets the studs?
1) Take out the kraft faced insulation and replace with un-faced insulation where the shower surround is??? Can i slit the paper with a blade a few times to open it up or what??
Tyler
tomknox is offline   Reply With Quote
Old 11-10-2011, 09:09 AM   #17
Bumpity bump bump
Old 11-10-2011, 12:09 PM   #18
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes I think so. That's been done a lot to my knowledge.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
tomknox (11-11-2011)
Old 11-29-2011, 08:22 PM   #19
Forgot to post some picture's but here they are. I put slits in the insulation and wanted to hang some durock. Bud here is the instructions which show the shim's, thats what i was asking about the paint stick's.
http://1.bp.blogspot.com/_R2dM_uHc6G...c/s400/tub.gif
1) Should i start with the back wall correct?
2) Should i install it vertical or horizonal?
Old 11-30-2011, 09:17 AM   #20
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Depending on actual dimensions of the walls I generally start with the back wall and lay the boards horizontally and then install the end-walls vertically. Doesn't matter which as long as the board edges are supported by a structural member.
Old 12-05-2011, 11:06 AM   #21
Thanks Bud!
1) Do i add structure around the bottom where it meets the tub also?
2) Every seem too i'm assuming?
Man this thing keeps snow balling!! Thanks
Old 12-05-2011, 11:44 AM   #22
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Generally seams that cross-over the stud bays don't require support behind them.
XXX
Old 12-06-2011, 01:11 PM   #23
Bud not sure that i follow you so here's what im talking about:
1) Do i need to brace the red lines?
2) Should i have braced the green line?
3) Should i brace where the drywall meets cbu above shower head (not pictured)
http://i75.photobucket.com/albums/i2.../paintbath.jpg
Old 12-06-2011, 01:44 PM   #24
Tileguy
Bud Cline's Avatar
Rewards Points: 558
1.) No.
2.) Already braced in close proximity...so No.
3.) No.
XXX
tiling tub surround -- how do I reach the upper corners? Alix Tiling, ceramics, marble 0 06-05-2011 01:05 AM
repair tiling and tub surround Commops106 Building & Construction 0 04-05-2011 07:11 PM
2-sided bath surround? Doylane Building & Construction 9 01-06-2011 10:21 PM
Tiling Bath Surround vleach Interior Decorating 1 10-26-2010 05:23 PM
Fireplace surround tiling Ducowti General DIY Discussions 8 10-28-2008 09:16 AM
