Tiling Around Tub : What Goes Behind The Tub Itself? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-06-2009, 07:24 PM   #1
Rewards Points: 81
Tiling around tub : what goes behind the tub itself?
I currently have a plastic surround glued to the drywall around the tub. There is some mold on the drywall near the top of the tub because the glue didn't stay very well. I am going to tile all around the tub now, but I'm assuming I will have to pull the drywall out down to the floor to get rid of the mold. So, can i just put the cement board in starting at the floor, then put the tub back in and start tiling Is there any reason I need anything besides backer board down there? Or, maybe I don't even need that?
Thanks in advance!
99miles is offline   Reply With Quote
Old 08-07-2009, 12:23 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 422
You have mold there mainly because of the drywall. It gets damp, and the paper feeds mold. Remove the drywall and replace with cement board, may want to consider applying a surface waterproofing membrane over the board too. Be sure to use thin set mortar that comes in a bag, nothing pre-mixed.
There is no drywall behind the tub. Tubs are installed against the studs way before the drywall. Bring the board down to the hanging flange, seal well then tile. Or, shim the wall out 1/4" to clear the flange. Plan ahead and do not remove the drywall past the last stud, cut at the center of the stud so the wb and cement backer have something to fasten to.
Jaz
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 08:37 AM
First tiling project, need some help DIYD Tiling, ceramics, marble 1 08-06-2009 06:15 AM
Tiling bathroom ivaiva Project Showcase 3 08-30-2008 08:24 AM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 03:44 PM
bathroom tiling neptunian General DIY Discussions 1 03-29-2005 07:44 AM
