Tiles And Thinset Got Wet Before Grouting - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-06-2012, 02:24 PM   #1
Tiles and thinset got wet before grouting
I set my tile and all went well. While I was waiting to apply the grout water leaked onto some of the tiles and thinset. The tiles had been in place about 10 hours when the leak happened. At first some of the tiles were "squishy" sounding when pressed and a little water came out at the edges. Now it mostly dry and tiles are firm when pulled on. Is it ok to go ahead with the grout, or must I wait until it's completely dry?
Flanly is offline   Reply With Quote
Old 07-06-2012, 05:32 PM   #2
DIY staff
Rewards Points: 7,174
Those tiles shouldn't have been 'squishy and water cane out' after 10 hours----did you use a powdered thinset or a premixed adhesive?
Old 07-06-2012, 06:06 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
How much water we talking about?..... Ended up on the floor. What did you place the tiles over? Backerboard, plywood, water proof mat?
This is the floor or wall?
JetSwet is offline   Reply With Quote
Old 07-06-2012, 06:48 PM   #4
Thanks!
Thanks for trying to help! Turns out I have an acquaintance who was able to help. All is fine with my project I just had novice panic.
The Following User Says Thank You to Flanly For This Useful Post:
oh'mike (07-06-2012)
Old 07-06-2012, 07:19 PM   #5
DIY staff
Well--what thinset did you use?
What thinset to use for large 12"x24" tiles on slab? NewHomeDIYGuy Tiling, ceramics, marble 39 06-29-2012 10:42 PM
glass tiles over kerdi (thinset question) Queso Bandit Remodeling 12 05-15-2012 04:08 PM
thinset between tiles in grout space amakarevic Flooring 2 06-10-2011 05:29 PM
How to remove thinset residue after old tiles removed? sz8 Flooring 11 01-01-2011 10:49 PM
glass tiles over kerdi (thinset question) Queso Bandit Tiling, ceramics, marble 1 04-17-2009 01:39 PM
