Tiles That Look Like Wood - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-19-2011, 02:17 PM   #1
Tiles that look like wood
I need to find a tile that looks like a wood. Here is the twist. This customer wants the tiles to have a circle in the corners that makes it look like nail down wood, but is a ceramic or porcelain product. I am in Oklahoma and can't find anything locally. I work for a company that has a large warehouse and can receive shipments from anywhere. Help!!
Tile guy Kevin is offline   Reply With Quote
Old 10-22-2011, 02:32 PM   #2
Rewards Points: 5,336
They used to sell that around here. Don't remember the nail hole part, just the "plank" shaped tile.
I'd check tile manufacturers on the internet. Many companies will have a store locator option where you can find their products if they have it in their product line.
Here's one:
http://www.classictileny.com/viewproducts.php?catid=43
There are plenty of companies that sell the product.
Ron
B. Franklin 1759
Old 10-23-2011, 11:38 PM   #3
as what I have known there's a certain tile wood that really fit for what the customer asking , its just more expensive than the normal tile but its adorable to look. that tile-wood is not easily to be found because it has legal paper works to process it and to sell it..I had already seen that tile-wood in a certain home and it really looks unique!!
Kaylee is offline   Reply With Quote
Old 10-24-2011, 08:36 AM   #4
Can you explain this remark, "that tile-wood is not easily to be found because it has legal paper works to process it and to sell it."?
Really interested in what legal restriction would cause this material to require "legal paper works".
Ron
B. Franklin 1759
Old 10-24-2011, 05:38 PM   #5
ron6519: thanks for the question..! as what I've known from a friend "tilewood is seldom to be bought" aside that its expensive it is also due to restrictions being made because the wood that in process of making tile wood are somewhat endangered trees that can't just be cut down without legal permits..
Old 10-24-2011, 07:44 PM   #6
Tile that looks like wood has no wood in it. It's a ceramic tile.
Ron
B. Franklin 1759
Old 10-24-2011, 07:59 PM   #7
really? ok i just figure it out that maybe I'm referring to another not the ceramic tile..I misinterpret the post I'm thinking of the wood itself..
Old 10-24-2011, 08:10 PM   #8
Poster said, " I need to find a tile that looks like a wood."
It helps to understand what the post is about.
Ron
B. Franklin 1759
Old 10-24-2011, 08:15 PM   #9
ok .. sorry about that .
Old 10-29-2011, 06:04 PM   #10
Company IWT carry some and Happy Floors. I think Daltile will have some to. I'm not sure if you have those company in your area but check with the flooring stores if they carry product from the company I listed.
Nika is offline   Reply With Quote
Old 08-08-2016, 07:59 AM   #11
DIY-Her's Avatar
Rewards Points: 239
Re: Tiles that look like wood
from what I have seen, most wood look tiles isn't ceramic, its porcelain that is much stronger. I found this old post because I searched the company "Happy Floors" :D
DIY-Her is offline   Reply With Quote
Old 08-08-2016, 03:35 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 412
FYI, porcelain IS ceramic. Although there's porcelain of many qualities, most floor tiles are porcelain these days since it's cheaper to make than it used to be. Doesn't mean that all porcelain is better than all ceramic tiles, but porcelain is stronger.
Jaz
Old 08-08-2016, 04:30 PM   #13
Rewards Points: 2,638
6 years later, I'm still trying to figure out what the OP is talking about.
SPS-1 is offline   Reply With Quote
Old 08-08-2016, 04:41 PM   #14
Tileguy
JazMan's Avatar
Rewards Points: 412
I didn't waste my time reading the whole thing again, it's immaterial. Just didn't want anyone to think porcelain is something other than ceramic.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
Gymschu (09-02-2016)
Old 08-14-2016, 05:09 PM   #15
DIY-Her's Avatar
Rewards Points: 239
Porcelain is a better and stronger version of ceramic. I remember looking it up a while back because I was wondering myself what the difference was.
Here ia a link I bookmarked that explains differences in both, and also some terms used for those that are researching it for the first time.
http://www.floorfacts.com/ceramic-porcelain-tile.asp
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Help Need Wood identification :D x3 iloveusk8rboi Carpentry 3 10-15-2010 09:05 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
