Tiles - Help, Porcelain On Plywood! - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-02-2008, 02:52 AM   #1
tiles - Help, Porcelain on plywood!
please please can anybody help me?i put down porcalin tiles in the kitchen on a marine ply wood base.my wife now wants differnt onestryed to get them up useing a hammer and bolster no luck,they just keep on splintering,only about a centrmetere comeing up at a time.also tryed a very large drill with flat head still no luck,anyone got any ideas?
davidmc is offline   Reply With Quote
Old 12-02-2008, 08:46 AM   #2
Rewards Points: 14
So you tried to lay porcalin tiles directly on top of ply wood? From what i've learned that is a big no no. I think you are going to ruin the ply when you try to take the morter off. I'm not an expert and someone will probably be along to confirm but i would think you would be better off tearing up the ply and starting over right. You might be able to leave the ply if you can get the tiles and morter up without tearing the ply apart but if you tried a big hammer drill with a chisel tip i don't think your going to get them up.
ponch37300 is online now   Reply With Quote
Old 12-02-2008, 08:56 AM   #3
Registered User
Termite's Avatar
The job was done incorrectly in the first place, considering the tiles were laid directly on plywood. You're better off starting from scratch with a proper tilebacker on top of your subfloor.
Tiles don't usually come off in one piece unfortunately.
Old 12-02-2008, 10:42 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The MP needs to come out and start over with the original subfloor. No one in the industry would have specified marine plywood, that's not what should have been used. Tiling directly to plywood can be done but isn't recommended. Especially if you plan to remove it later.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 07:29 AM
Laying Porcelain Tiles Over Gypcrete @ Lino Janet Flooring 11 07-30-2008 05:38 PM
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 06:28 PM
Porcelain Garage Tiles? head_dunce Flooring 6 02-22-2007 04:28 PM
