Tiles On A Deck WITHOUT Being Fixed In Place? - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-30-2011, 09:18 PM   #16
Craftster
ghostlyvision's Avatar
Rewards Points: 95
There are several kinds of rubber deck tiles you could use, here's just one example:
http://www.diamond-safety.com/Deck,%...0Products.html
ghostlyvision is offline   Reply With Quote
Old 02-10-2012, 06:39 PM   #17
Pro
JetSwet's Avatar
Rewards Points: 502
Originally Posted by AmyDS
Hello,
I've read enough online to know that tiling on a deck is a bad idea, that changes in climate will cause the subflooring to expand and contract and will eventually crack the tiles.
There are, however, a lot of people on various sites giving advice on how to succeed doing this, but just as many people warning against it.
I'm not wiling to take the risk - I live in Canada, where extreme weather changes are a fact of life.
However, I have an idea that I'd like to run by the tiling experts out there.
What if I were to lay outdoor tiles (porcelain, slate, etc) on top of a raised wood deck, but not glue, cement, or grout them in place. I would then build a wooden frame around the perimeter of the tiled area to keep the tiles from moving around.
Would this work? Any ideas will be greatly appreciated. FYI, I'm looking to cover the deck with a fixed roof, if that matters.
Amy
http://www.tileyourdeck.com/
This makes it possible to tile on your deck.
Sent from my iPhone 4 ios5
JetSwet is offline   Reply With Quote
Deck Height Issue/ Re-Grading help req.. lepricon_01 Building & Construction 16 06-03-2011 09:24 PM
new house we want an affordable deck with porcelain tiles moni Building & Construction 1 05-28-2011 07:28 PM
Is it SAFE not to use deck post concrete anchors? z_zk_z Building & Construction 3 06-28-2010 10:35 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
