Tiles - Ceramic Or Porcelain - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 08:55 PM   #1
Rewards Points: 87
Tiles - ceramic or porcelain
Is there much of a difference between ceramic and porcelain tiles?
Their final resting spot will be on a shower wall.
They wont have any foot traffic of course, but was wondering if one was perfered over the other for durability and crack resistance...
phantasm72 is offline   Reply With Quote
Old 02-17-2011, 09:40 PM   #2
Civil Engineer
Rewards Points: 4,938
Porcelain is a type of ceramic that is made from clay fired at a high temperature for a relatively long time. Ceramic is a more general term that refers to a variety of products, including some metal/glass composites. Most tiles sold in the store are porcelain, however you can get tiles fired at lower temperature (Mexican clay tiles come to mind). For a shower wall, you want tile that is rated for high moisture exposure conditions.
Daniel Holzman is online now   Reply With Quote
Old 02-17-2011, 10:17 PM   #3
Rewards Points: 81
I can't imagine how you would break either type of tile on a wall -- unless the wall was flexing a lot. I have ceramic tile on my garage floor. I jack my car up on it without any issues.
Porcelain is even harder.
Jack Olsen
The 12-Gauge Garage website
My Car
Jack Olsen is offline   Reply With Quote
Old 02-18-2011, 06:39 AM   #4
DIY staff
Rewards Points: 7,174
You will be fine with either ceramic or porcelain in that situation---Ceramic is less brittle tan porcelain and easier for the installer to cut or drill.
Old 02-20-2011, 06:45 PM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I tiled my shower last year and finally chose a porcelain tile. It came down to two issues for me. First, the one I chose had a (relatively) smooth surface so it would be easier to clean. Second, the body of the tile was the same color as the surface. I knew I was going to be doing a lot of cuts and didn't want to risk a different color showing.
Old 02-20-2011, 07:07 PM   #6
DIY staff
Blondsense--You chose a very high quality tile there----I love working with the solid porcelain.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Need to replace 4 3x3 ceramic tiles around shower. babaganoosh Tiling, ceramics, marble 1 12-28-2010 08:40 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 06:29 AM
another tile question: installing large (1'x2') porcelain wall tiles diy'er on LI Tiling, ceramics, marble 4 09-16-2009 01:57 PM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 09:01 AM
