Tiles - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-28-2013, 10:28 PM   #1
tiles
is mesh required before laying porcelain tiles in a kitchen floor?
enshan is offline   Reply With Quote
Old 04-29-2013, 12:40 AM   #2
DIY staff
Rewards Points: 7,174
What would the mesh be used for?---Use a good concrete backer board set in thinset and nailed---
Mesh under tiles is a poor method of setting tiles---
JetSwet (04-29-2013)
Old 04-29-2013, 10:36 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 220
Enshan,
The method you're referring to is called "scratch-coat" or "Jersey-Mud Job". It's not an approved method of setting floor tiles, but it's done every day. It has a high failure rate, but probably works well long term 70-80% of the time. That is not good.
The method has been tested by the TCNA and TTMAC, the Canadian equivalent, and has failed every time. Why is it used so much in Canada? It's cheaper to do, so tile setters who use it don't want to do a better job and lose jobs and money.
Tell us more about your tile project.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
JetSwet (05-05-2013)
Replacing 2 ceramic tiles over Ditra RichardZ Flooring 33 01-17-2013 01:22 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Need to replace 4 3x3 ceramic tiles around shower. babaganoosh Tiling, ceramics, marble 1 12-28-2010 09:40 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 07:29 AM
calking backer board to tub glassman General DIY Discussions 13 06-19-2008 09:41 PM
