Tilers Mesh For Tile Seams - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-16-2013, 03:42 PM   #1
Tilers Mesh for Tile Seams
When meshing cement board to cement board seams, should I use the Fiba self-adhesive tape, then a thin layer of thinset? or thinset in the gap (between the cbu seams), then Fiba tape, then another thin layer of thinset? or, should I use a non-adhesive tape?
Also, is it safe to assume that I can use the above same mesh tape to mesh the seams between the cement board and greenboard?
BTW, I'm using durock sheets. Thanks all.
Jay2013 is offline   Reply With Quote
Ceiling seams wwkayaker Drywall & Plaster 9 10-25-2014 12:19 PM
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 01:04 PM
how to make a cylindrical box out of mesh anorphirith Building & Construction 2 02-25-2013 12:20 AM
allure flooring coming up at seams & corners Mavis Flooring 22 08-20-2012 02:07 PM
Mesh Tape dustinfox Drywall & Plaster 10 03-02-2012 09:53 PM
