Tile, Thinset & Door - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-07-2013, 06:15 PM   #1
Rewards Points: 151
Tile, thinset & door
I need to install a new door unit in a space that is to receive tile. I'm also installing a door to a room that won't receive tile for a year or more. How much height will thinset and 8mm porcelain tile add to a concrete floor? TIA.
Bob... is offline   Reply With Quote
Old 02-07-2013, 09:04 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 226
Assuming you mixed the thinset just right and use a 1/4x3/8x1/4 trowel, I' d say a total of 11 mm max. Might be closer to 10 mm.
How much space do you intend to leave for throw-rugs and air movement?
Jaz
JazMan is online now   Reply With Quote
Old 02-07-2013, 10:03 PM   #3
Rewards Points: 151
Jaz
I won't be installing the tile myself, so I can't say exactly what trowel will be used.
As far as space, I guess I'll need no more than 1/4" to 1/2" gap between the installed floor and the door bottom. An automatic threshold will be installed that drops down 3/4" or less.
Old 02-07-2013, 10:11 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 226
The proper trowel depends on the type and size of the tiles. Is the floor flat and therefore ready to go, or is some patching needed to get it flat? Is this a residence or your office?
Jaz
Old 02-07-2013, 10:23 PM   #5
Rewards Points: 151
Jaz
Thanks for your remarks Jaz.
The floor will need some leveling, as there are some low ("un-flat") areas, and it is a business office within my residence. 18"x18" tiles. I'll let whatever contractor I choose level the floor.
There is also a crack in the concrete (slab is not sinking) that will need membrane, in case that's relevant. It runs the width of the slab and is about 4' from the previously mentioned door.
Old 02-07-2013, 10:48 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 226
I wouldn't be installing any doors or jambs until the floor is done.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
Bob... (02-07-2013)
Old 02-07-2013, 11:09 PM   #7
Rewards Points: 151
Jaz
I think that makes sense. The tile is holding the job up, but I can see that putting B before A may cause further delays down the road. Thank you for your advice.
Question about pre hung exterior door and tile gta Flooring 0 08-06-2012 05:04 AM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 07:50 AM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 10:00 PM
Removing Thinset from Badly Installed Tile bobbygarafolo Tiling, ceramics, marble 2 04-21-2010 02:29 PM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 04:19 PM
