Tile, thinset & door
I need to install a new door unit in a space that is to receive tile. I'm also installing a door to a room that won't receive tile for a year or more. How much height will thinset and 8mm porcelain tile add to a concrete floor? TIA.
Assuming you mixed the thinset just right and use a 1/4x3/8x1/4 trowel, I' d say a total of 11 mm max. Might be closer to 10 mm.
How much space do you intend to leave for throw-rugs and air movement? Jaz |
As far as space, I guess I'll need no more than 1/4" to 1/2" gap between the installed floor and the door bottom. An automatic threshold will be installed that drops down 3/4" or less. |
The proper trowel depends on the type and size of the tiles. Is the floor flat and therefore ready to go, or is some patching needed to get it flat? Is this a residence or your office?
Jaz |
The floor will need some leveling, as there are some low ("un-flat") areas, and it is a business office within my residence. 18"x18" tiles. I'll let whatever contractor I choose level the floor. There is also a crack in the concrete (slab is not sinking) that will need membrane, in case that's relevant. It runs the width of the slab and is about 4' from the previously mentioned door. |
I wouldn't be installing any doors or jambs until the floor is done.
Jaz |
| All times are GMT -4. The time now is 08:38 AM. |
