Tile Step To Step Safley In To The Tub Is That A Good Thing Or Not. - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 03:05 PM   #1
Tile Step to step safley in to the tub is that a good thing or not.
Will people trip over a tile step in bath room floor we nead a step the yub is 22 in. high Thanks Gary
Gary Gschwind is offline   Reply With Quote
Old 02-05-2011, 04:44 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
Hi Gary,
I don't think a step at a tub is a very good idea at all. Even if you installed a couple assist grab bars. Why can't you sit on the edge and swing into the tub? Got a pic?
Jaz
Old 02-05-2011, 06:45 PM   #3
Old School
Willie T's Avatar
I'm with Jaz. NEVER put a step inside or outside a tub!
Two reasons:
1. They will be slippery when wet. VERY DANGEROUS!
2. They make the two bottoms of the opposite sides of the tub wall different heights. This will throw off your brain and create a fall hazard.
Willie T
duct wrap plus add'l insulation - too much of a good thing? rtoni HVAC 6 09-10-2010 02:23 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 07:19 PM
tile on tile? kshankle Flooring 37 06-23-2008 05:04 PM
