Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 03-13-2013, 03:05 PM   #1
Tile Size
Is there a rule-of-thumb for sizing ceramic tile?
We have a small area (about 4ft. X 5ft.) that we would like to tile.
It is an older house, so the area may not be perfectly flat and level. What would be the optimum tile size to use?
Thank you.
frank999 is offline   Reply With Quote
Old 03-13-2013, 03:39 PM   #2
Tile Size
Level does not matter to much, but it has to be flat and not flex at all.
Installing it on a diaginal will make it look like a larger area.
Smaller tiles like 6 X 6 or 8 X 8 will work best.
Old 03-13-2013, 07:38 PM   #3
Tileguy
JazMan's Avatar
Tile Size
I think the rule of thumb is what ever Mrs. Frank wants.
Large tiles in a small room actually work very well. Well, I mean they look fine, just a pita for the installer.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 03-13-2013, 10:17 PM   #4
Tile Size
Originally Posted by frank999 View Post
I
check just how "flat" the floor is. if it is wavy, small = 1-2" tiles will be far easier to properly install. the larger the tile, the more work there will be, unless the floor is very flat. then they are very easy.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 03-13-2013, 10:21 PM   #5
Tile Size
oh. if you decide to use large tiles. mix up some thinset. then use a straight edge to find the low spots. then ALMOST fill the low spots. let dry and recheck. do again if needed till its pretty much flat.
Old 03-15-2013, 02:35 PM   #6
Tile Size
Thanks for all your replies. we are considering the options.
Old 03-25-2013, 01:04 PM   #7
Sephora's Avatar
Tile Size
I just did 12x24 the long way in my 4.5x7.5 half bath...came out pretty nice. Used thin grout lines 1/16th.
Sephora is offline   Reply With Quote
Old 04-09-2013, 05:57 AM   #8
Tile Size
RoofContractor is offline   Reply With Quote
tile size laorquidia Flooring 16 09-17-2012 09:54 PM
Nominal Size of Tile, Lowes/HD vs Tile Store Thadius856 Flooring 17 09-12-2011 09:16 PM
tile size shappire Tiling, ceramics, marble 2 09-11-2011 11:24 PM
Tile Size Recommendation for Laundry Room MarksHouse Flooring 3 10-21-2008 02:38 PM
What size floor tile? skipjack Flooring 1 09-22-2008 11:39 AM
