Tile Size - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 09-11-2011, 05:05 PM   #1
tile size
Can i use any size tile on a shower floor?
shappire is offline   Reply With Quote
Old 09-11-2011, 06:02 PM   #2
m1951mm's Avatar
Because of the slip and slid issue most shower floors are done with 2" or less tiles. You will have more grout joints but that helps with traction 3 is ok but getting any bigger make sure you have gooooood Grab Bars!!!!
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
Old 09-11-2011, 11:24 PM   #3
firehawkmph's Avatar
Rewards Points: 1,800
Shap,
besides the slipping, depending on how your shower floor is sloped, smaller tiles fit the slopes better. It is common to have the floor slope from all four directions to the drain. Too big a tile will cause a problem where the changing slopes meet. Better off staying with 1-2" tiles.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
m1951mm (09-12-2011)
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 02:35 PM
Tile Size Recommendation for Laundry Room MarksHouse Flooring 3 10-21-2008 02:38 PM
What size floor tile? skipjack Flooring 1 09-22-2008 11:39 AM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
Subway tile installation bigboyjoel Flooring 3 08-02-2007 08:15 AM
