Tile Shower Surround Above Fiberglass Shower - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-26-2011, 09:30 AM   #1
Tile shower surround above fiberglass shower
I installed a large walk in fiberglass shower to accomodate the wifes senior Mom and time was essential then. We are quite comfortable with it and want install 2 in square tiles on the high surround and ceiling now that we are the ones using it. When I put it in I used green board and did not change the ceiling drywall. Can I put the sheet tiles directly on that original dry wall on the ceiling? The demensions of that area is 47 X 34 in.
The new shower replaced a standard tub - shower unit, (f-glass).
Your Recomendations will be most appreciated.
Gregg
Gregghea is offline   Reply With Quote
Old 01-27-2011, 10:21 PM   #2
Registered User
Rewards Points: 5,498
Welcome to the forum! I'll move you to "Tile" for some answers...
Gary
Old 01-28-2011, 05:34 AM   #3
DIY staff
Rewards Points: 7,174
Yes, that is not a wet area--tile over the drywall--O.K.
Old 01-28-2011, 07:39 AM   #4
A Little Of Everything
Rewards Points: 1,364
As usual, I agree with Mike.
The only problem would be if there's water damage on any of the drywall above the shower.
DrHicks is offline   Reply With Quote
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Using a tub surround for shower surround Sbruce Building & Construction 2 08-21-2010 07:21 AM
Tile or fiberglass shower? Proby Tiling, ceramics, marble 18 07-26-2010 04:49 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
