Tile Remover - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 09-28-2010, 08:16 PM   #1
tile remover
what is the best way to remove thinset from a concrete floor
queeny is offline   Reply With Quote
Old 09-28-2010, 08:40 PM   #2
How many square feet? Get a chipping gun with a thin blade and chip it up. Its the easiest cheapest way. If its a large area, get a grinder.
wnabcptrNH is offline   Reply With Quote
Old 09-29-2010, 07:09 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...........or just use a wet sponge!
If you had said "how much". . . "where it is" . . . "how it got there", someone would know a little more about how to help you. Any tiny tidbit more of information would be very helpful.
XXX
Old 10-12-2010, 12:24 AM   #4
Rewards Points: 978
i have the same question-i got ceramic tile in the basement. not sure whats beneath but i suspect its the foundation block floor. whats best way to remove the tile/thinset? thanks!
federer is offline   Reply With Quote
Old 10-12-2010, 05:40 AM   #5
DIY staff
Rewards Points: 7,174
A rental store will have a floor buffer with carborundum stones----fast and effective--use a spray of water to keep the dust down.
You will need to hand scrape the corners.---Mike---
Old 10-12-2010, 10:31 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
. . . and a wet-vac to pickup the resulting slurry.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
federer (10-21-2010)
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
