Tile Removal Using Demo Hammer. Which Bit? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-09-2014, 04:56 PM   #1
Rewards Points: 24
Tile removal using demo hammer. which bit?
I got a 22lbs demo hammer on craigslist that I plan on using to remove 1000 sq ft of ceramic tile. It uses SDS Max bits. Should I got with a wide chisel bit or a floor scraper head? I'm thinking chisel because I'm assuming I might need to rent a floor grinder anyways to get the thinset off... A wide chisel will be alot cheaper if that's the case....
Any suggestions? Thanks, Chris
stupid48 is offline   Reply With Quote
Old 02-09-2014, 05:01 PM   #2
Rewards Points: 13,732
I just use a 2" wide bit with a raised area in the center of it.
It lifts and splits the tiles.
Get some knee pads and goggles.
Old 02-09-2014, 06:28 PM   #3
DIY staff
Rewards Points: 7,174
I agree with Joe----that's a heavy machine--you better be a strong one---
Old 02-17-2014, 07:49 PM   #4
When I did the 1200sqft in my house I used a 4 inch flat blade, it worked well. I was lucky enough to be on concrete and just used the 4 inch flat blade to remove the remaining thinset. Prepare to sweat, it's a lot of work with clean up.
Mbjason is offline   Reply With Quote
Old 02-27-2014, 08:10 PM   #5
Rewards Points: 4,796
9 times out of 10 the tile was installed poorly, and it might come up very easily!
jeffnc is offline   Reply With Quote
Tile demo to lay vinyl... bstaff03 Flooring 3 03-30-2013 08:04 PM
hatachi DH84YE demo hammer bernie963 Electrical 5 03-25-2013 04:28 PM
How to remove single 18" ceramic floor tile hkeiner Tiling, ceramics, marble 8 02-28-2013 09:56 AM
Ceiling tile removal - how hard? mrs1885 Remodeling 1 01-07-2011 02:24 PM
Newbie to 1950's house - tile adhesive removal? FixyChik General DIY Discussions 20 01-08-2009 09:34 AM
