Tile Ready - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-31-2011, 12:31 AM   #1
Tile ready
I put in a tile ready pan and before I have tiled I have a lot of flex. Is the Schluter®-KERDI memebrane the answer?
E
It sounded good is offline   Reply With Quote
Old 05-31-2011, 01:19 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
If you are talking about these products: http://www.tileredi.com/ then you might want to check out this old thread:
Tile Redi Shower pan question
If you look at the dates you'll see the thread was started over two years ago. Maybe they have made improvements since then.
The Following User Says Thank You to Blondesense For This Useful Post:
It sounded good (05-31-2011)
Old 05-31-2011, 06:53 AM   #3
It doesnt seem as if they have made any improvements.
I was thinking of screwing the redi pan down and going over the pan with LATICRETE Hydro Ban.
Old 05-31-2011, 11:01 AM   #4
Stuck in the 70's
Still, if you're going to tile, any flex or movement will ruin it.
Old 05-31-2011, 11:57 AM   #5
Hopefully counter sinking the screws on the rib line will take the flex out. Then I would cover that area with red guard .
Old 05-31-2011, 07:46 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
It Sounded Good,
Did you read the above link? The answer is there in Post #5.
I don't think liquid waterproofing will stick to the Tile-Redi product.
XXX
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Installed a new Styrene tub, getting ready to tile above. Durock, or hardibacker? J187 Remodeling 3 03-31-2009 07:49 AM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
Tile Cutter vs. Tile Saw jamiedolan Flooring 8 11-09-2008 03:17 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
