Tile Over Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 11:08 AM   #1
Tile over Tile
Im planing to re-tile the house, it was suggested i tile right over the existing, however the bedrooms used to have carpet, now they want tile in those rooms as well which means I will have transition issues at the doorways. any suggestions??
lenniep is offline   Reply With Quote
Old 01-19-2012, 06:19 PM   #2
DIY staff
Rewards Points: 7,174
First things first---Is the existing tile installed properly and in perfect condition? Is the only objection to the tile its looks?
If perfect and properly installed then you can overlay tile using two part thinset--like Kerabond and Keralastic---"Mud" What Is It? - Kitchen & Bath Remodeling - DIY Chatroom - DIY Home Improvement Forum
As to the low areas---you will want to raise them----what kind of floor structure--concrete slab or wood frame?
Old 01-20-2012, 07:23 AM   #3
mike owes me $53 dollars
Tech Dawg's Avatar
Lennie,
Be sure to use high quality products like Mike suggested and for the transitions you can look into a variety of different Marble or Schluter transition strips. Most likely you would need a Single Hollywood Bevel marble strip or if the heights are a difference of more than 3/4 you can also check with your local granite or corian shop to fabricate some for you
Tech Dawg is offline   Reply With Quote
Old 01-20-2012, 07:32 AM   #4
DIY staff
If the floor is wood---you might be able to raise that old carpeted area with a cement backer board--
Need more details---a picture would help,too.
Tech Dawg (01-20-2012)
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 06:03 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 03:06 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
