Tile Over A Painted Wood Cabinet That Abuts A Garden Tub - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 04:58 AM   #1
Tile over a painted wood cabinet that abuts a garden tub
My garden tub abuts a painted wood cabinet. It is tiled on all the other sides, but I'd like to tile the side of the cabinet so water can't damage the side. If I put a cement backer over it first, it will be too thick and look bad from the front edge.
kweatherston is offline   Reply With Quote
Old 08-06-2011, 07:35 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Liquid waterproofing.
Redgard from Home Depot maybe.
XXX
Old 08-06-2011, 10:50 PM   #3
tile over a painted wood cabinet
What would you use to stick the porcelain tiles to the surface with after the waterproofing is applied?
Old 08-07-2011, 02:35 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Midified thinset tile mortar.
XXX
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Ceramic Tile that looks like Hard Wood floor Rhonda H. Flooring 31 08-15-2012 04:53 PM
ceramic tile stairs with wood nosing karenk Flooring 0 03-17-2010 10:30 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Tile with a wood trim? trick29392 Flooring 3 06-26-2008 07:19 AM
