Tile Over Luan - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 08:47 PM   #1
tile over luan
I cut a 6 ft. arch between livingroom and dining room to open the area up. Friend attached luan to the inside of the arch, knowing I wanted to tile the inside of the arch. Now realize I shouldn't have used the luan. Is it possible now to attach with galvanized screws some wire lathe, put a thin coat of mastick then attached the tile to the wire & mastick? If doable, how long might it last?
Tina McDOnald is offline   Reply With Quote
Old 11-08-2010, 09:49 PM   #2
Rewards Points: 292
That sounds like a bad idea. Why not tear off the luan and use proper backer board. I've never tiled an arch but I imagine you would want something like 1/4" Hardibacker that will likely conform to your arch, Hopefully one of the tile experts will weigh in.
Jim F is offline   Reply With Quote
Old 11-09-2010, 04:33 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Everywhere you go, everywhere you look, everything you read, specifically excludes the use of luan in any tile project. Anyone using luan should be slapped around in a dark alley late at night. To cover it with mastic and keep going means the firing squad.
Take it out and do as suggested above.
XXX
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Luan plywood staples under tile? former33t Flooring 3 10-15-2009 01:34 PM
Tile over, or tile under? jeffyisfive Flooring 4 01-24-2007 11:29 AM
Vinyl tile over luan? irishghandi Flooring 1 03-08-2006 02:46 PM
