Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 02-18-2013, 02:50 PM   #1
tile over linoleum
I am sure this is a silly question, but here it goes. Is it OK to tile over linoleum? Will be tiling our kitchen and was wondering if we really need to try and remove the linoleum or can we tile over it. Thought about putting down some type of concrete board but that will make the floor a lot higher than the floor from hallway. Right now the linoleum is stuck to floor well and not coming up anywhere that I can see. If it was would defiantly remove. Will be putting down ceramic or porcelain tile (wife bought tile and I can't remember which it was).
Thanks for the help.
merlin66043 is offline   Reply With Quote
Old 02-18-2013, 03:36 PM   #2
tile over linoleum
if it has lineoleum it probably has 1/4 underlayment under it which needs to come up.
Old 02-18-2013, 03:52 PM   #3
JetSwet's Avatar
tile over linoleum
The guys on here will want to know how thick your subfloor is as well as what your substrate is being help up with ect joist size and span. You need a approved substate for tile before you tile.
Aslo yes take the 1/4" out with the linoleum attached you will kill 2 birds on stone that way.
JetSwet is offline   Reply With Quote
Old 02-18-2013, 04:07 PM   #4
tile over linoleum
Not sure what is under the linoleum. House is only about 12 years old so joist span would be code and I think they used engineered joists.
Sounds like should take up though.
Old 02-18-2013, 06:15 PM   #5
JetSwet's Avatar
tile over linoleum
Yeah it would be built to code to be able to walk on and carry weight but tile requires less deflection.... (up and Down movement) for example your joists could be 24" apart instead of 16 on center, so there would be 2 different attack methods.
Tile over linoleum Wolfefam Flooring 12 02-25-2013 01:00 PM
Transition from linoleum to ceramic tile... roasted Flooring 3 04-24-2012 11:44 PM
ceramic tile over linoleum on concrete base mattbr38 Flooring 2 03-11-2012 06:58 AM
Water 'seeping' from linoleum on top of tile ewerbeck Flooring 22 01-02-2012 11:51 AM
Ceramic tile over linoleum john curry Tiling, ceramics, marble 1 08-29-2009 01:34 PM
