Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 03-25-2012, 08:40 PM   #1
Tile over existing ceramic tile
I am in the process of remodeling and have glossy ceramic tile in the kitchen. Can I tile over this tile or do I have to remove it?
Note: Existing flooring- Slab on grade/Glossy Ceramic Tile
Not worried about heights, they are ok.
jgb29 is offline   Reply With Quote
Old 03-26-2012, 07:30 AM   #2
Super Moderator
It would be best to remove the tile.
However you can tile over existing tile---scarify the old tile--an angle grinder with 36 grit paper works well
vacuum and set using a two part thinset-http://www.diychatroom.com/f80/mud-what-77763/
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
JetSwet (03-26-2012), jgb29 (03-26-2012)
Old 03-26-2012, 08:39 AM   #3
Thanks Mike! Some places have said that you should not tile over glossy finished tiles others said its fine.
Old 03-26-2012, 08:43 AM   #4
Super Moderator
If you mix your own modified thinset you will be fine---Kerabond and keralastic is a good example.
Old 03-26-2012, 12:50 PM   #5
Stuck in the 70's
Blondesense's Avatar
Edited:
Oops, never mind.
Didn't read original post correctly.
Blondesense is online now   Reply With Quote
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
install outlet through existing tile? hoosadam Electrical 3 02-01-2011 01:47 PM
Existing Ceramic Tile Entry Way toddack Flooring 5 06-14-2010 11:51 PM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 10:01 AM
a couple of ceramic tile install Q's DanBress Flooring 5 06-22-2008 11:01 PM
