-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Tile over existing ceramic tile (http://www.diychatroom.com/f84/tile-over-existing-ceramic-tile-138232/)
jgb29 03-25-2012 07:40 PM
I am in the process of remodeling and have glossy ceramic tile in the kitchen. Can I tile over this tile or do I have to remove it?
Note: Existing flooring- Slab on grade/Glossy Ceramic Tile
Not worried about heights, they are ok.
oh'mike 03-26-2012 06:30 AM
It would be best to remove the tile.
However you can tile over existing tile---scarify the old tile--an angle grinder with 36 grit paper works well
vacuum and set using a two part thinset-http://www.diychatroom.com/f80/mud-what-77763/
jgb29 03-26-2012 07:39 AM
Thanks Mike! Some places have said that you should not tile over glossy finished tiles others said its fine.
oh'mike 03-26-2012 07:43 AM
If you mix your own modified thinset you will be fine---Kerabond and keralastic is a good example.
Blondesense 03-26-2012 11:50 AM
Edited:
Oops, never mind.
Didn't read original post correctly.
