Tile Over Brick/terracot - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-27-2013, 08:00 PM   #1
Tile over brick/terracot
Hi -
I recently demoed my bathroom and am getting ready to start putting it back together. It is a 90 year old house and built out of terra cotta bricks with an brick exterior (not a stick frame).
I am putting in a tub where one side will be against the exterior brick wall. The wall is not flat/even. Before I took out the tub, there were old subway tile that were cemented directly onto the terra cotta. The cement ranged from 1/2 to 1 1/2 inch thick depending on the imperfection in the tile. My question is how to mount new tile on the wall after I put the new tub in. My thought was to:
1. Install the tub first flush with the wall
2. Float thinset on the terra cotta blocks (no fasteners - can't really drive them into the terra cotta bricks - they shatter)
3. Set 1/2 hardibacker into the thinset to provide a flush level surface for the tile
4. Seal the hardibacker with Redgard
5. Apply subway tile with thinset.
In addition, by the time I'm done, thickness of materials on the blocks will be approx 1 1/2 - 2". Too much overhang for the edge of the tub? Should I back the tub an inch or two from the wall before I start adding the surface?
Any thoughts? I'm worried about just putting the tile straight on the terri cotta due to the uneveness of the the surface; I was hoping that the hardibacker would provide the nice smooth surface. I included a picture of the terra cotta blocks for reference.
Any thoughts are appreciated
Tile over brick/terracot-wall-terra-cotta-exposed.jpg
JP's Dad is offline   Reply With Quote
Tags
tile brick terra cotta
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 06:03 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 03:06 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
