Tile Over Basement Concret (that Got A 1/2 Inch Of Water Once) - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-06-2010, 04:09 PM   #1
tile over basement concret (that got a 1/2 inch of water once)
HI,
I have lived here for 14 years. About 4 years ago the rains were very heavy for many many days and the underground stream at the back of the house swelled so bad water came up from my basement floor. The cellar only had about 1/2 of water around the edges.
Now I have the chance to change my lone working tolet to a 1/2 bath in the cellar. The area has all the drain valves in place. A handyman friend owes me a big favor and will help do the work. I would like to put tile on the floor but I worry about the every 14 year water invastion. How can I protect these tiles? Can I put pressure treated wood over the concret, or a sub floor, then lay the tiles?
Mary
mroberge is offline   Reply With Quote
Old 01-06-2010, 05:07 PM   #2
As long as it's dry and set before the next flood, you'll be fine.
R&D Tile is offline   Reply With Quote
Old 01-06-2010, 10:01 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Not to worry, go for it. It isn't very likely another flood will hurt a properly installed tile job. Not impossible but very improbable. Think about all the tiled swimming pools and spas around the world.
XXX
Old 01-07-2010, 06:46 AM   #4
Don't use mastic, use thinset mortar, it is waterproof once it sets up.
Old 01-07-2010, 02:44 PM   #5
Water resistant, not waterproof.
Old 01-07-2010, 02:59 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Good catch there Dead-Eye!
XXX
Old 01-07-2010, 05:24 PM   #7
THanks! I will do that.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Water seeping though bottom of basement stairs Sforza General DIY Discussions 18 03-11-2011 02:42 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 06:07 PM
Advice for a novice: Mold and water damage in basement xoxJanette General DIY Discussions 1 12-29-2009 07:54 AM
Interior perimeter drain for basement water joshm General DIY Discussions 9 05-30-2009 10:08 AM
