Tile On An Outdoor, Covered Porch (first Post!) - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-21-2013, 07:32 AM   #16
Rewards Points: 195
Do not tile directly to the plywood. The wood will swell and contract with the seasons. You need a membrane to absorb these forces. Noble Deck is my preferred exterior membrane; Ditra next. Keep in mind some membrane manufacturers want a cement base (that rules out Hardi backer) under the membrane.
You also need a premium thinset. Laticrete Platinum or Kerabond+Keralastic liquid.
A porcelain tile rated for exterior use is a great choice.
Always plan on the worst case scenario when tiling outside. Why do it over?
olzo55 is offline   Reply With Quote
The Following User Says Thank You to olzo55 For This Useful Post:
oh'mike (09-21-2013)
Old 09-21-2013, 08:11 AM   #17
Rewards Points: 4,796
Keep in mind that these are modified thinsets, and are for use under Ditra but not above it. (Don't know about Noble.) Kerabond by itself would be used to set the tile.
Also, I'd personally use Ultraflex rather than mixing in the additive (Keralastic), but to each his own there.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
olzo55 (09-22-2013)
Old 09-21-2013, 11:44 AM   #18
Rewards Points: 195
Noble allows the modified thinset but requires 50% longer drying time before grouting.
Tags
plywood subfloor , slate , tile
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
fixing a porch post in concrete it99 Building & Construction 2 10-21-2011 07:27 AM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
can i tile my porch? njmike Tiling, ceramics, marble 4 06-26-2011 06:03 PM
mounting 4x4 wood post to concrete porch pshinaults Building & Construction 1 05-27-2010 02:53 PM
