Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 05-28-2012, 11:50 AM   #1
Tile layout in small bathroom
I have 1' X 2' tile which I will be laying horizontally on the floor then into the shower, which is straight ahead of the entrance to the bath. Would the tile look best in a brick pattern or just aligned next to each other?
tiled is offline   Reply With Quote
Old 05-28-2012, 12:20 PM   #2
In a little over my head
Brick pattern looks better to me. Are you using the same tile on the walls of the shower? Run the tile lengthwise on the floor, then horizontally on the walls to give more visual interest.
ratherbefishing is offline   Reply With Quote
Old 05-28-2012, 12:31 PM   #3
Stuck in the 70's
Blondesense's Avatar
It is very much a matter of opinion.
I would just lay them out on the floor and see what looks best to you.
I know you didn't ask this, but have you tiled much before?
Tiles that large require an absolutely flat surface. Be aware they can be very difficult for a beginner.
Blondesense is online now   Reply With Quote
Old 05-28-2012, 07:09 PM   #4
Super Moderator
Well said--I suggest you read up on tile leveling systems--Lash by QEP is one--Tuscan is another.
You said you were running this into the shower?
What are you doing ,exactly?
Tile size pros and cons for bathroom wall. Jim F Kitchen & Bath Remodeling 12 02-29-2012 11:11 AM
Removing Bathroom Ceramic Tile Laid in 1970 mark2741 Flooring 6 12-08-2011 09:55 AM
Piping Layout for New Bathroom structman Plumbing 2 02-23-2010 06:24 PM
Options for Old Bathroom Tile Floors mark2741 Flooring 4 11-14-2009 12:21 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 07:08 PM
