Tile Installation Over Gypcrete With Ini-floor Heat - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-11-2012, 03:31 PM   #1
tile installation over gypcrete with ini-floor heat
what is the proper method of installing floor tile over gypcrete with in-floor (water/tubing) heat
tjmez1 is offline   Reply With Quote
Old 05-11-2012, 06:19 PM   #2
DIY staff
Rewards Points: 7,174
If it's level--modified thinset is the usual product---
Self leveling compound might be needed before setting if the gypcrete is not flat.
Old 05-11-2012, 09:58 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 388
Gypcrete & all gypsum substrate are a poor base for tile. You should research what Maxxon has to say about tiling over it. You'll find there are special notes on the thin set mortars for use over gypsum.
One good way is to install Ditra over the warming wires or hydronic tubes and then your tiles. This deals with Ditra and gypsum. http://www.schluter.com/5352.aspx
Jaz
Tile Redi Shower pan question oc250r Kitchen & Bath Remodeling 179 04-17-2017 09:03 AM
Porcelain Tile installation Fields31 Tiling, ceramics, marble 8 10-08-2011 10:25 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Glass Tile Installation hms2205 Tiling, ceramics, marble 2 06-20-2009 07:46 PM
Ceramic Tile Backsplash Installation DK75 General DIY Discussions 4 11-01-2006 07:56 PM
